free website stats program Need some help | Harley Davidson Forums
Need some help
01 rk
Changed out the cam bearings on the RK everything went well until I tried to install the cam support plate, will not go back on, hung up on something.
I can't see if the cams and bearings are lined up. I inserted two guide pins to help line it up but they did not help. Did I miss something?
Thanks for any advise or help.
did you keep the rear tensioner retracted? if you move the retension pin to the out side of the cam plate that should help. you want the cams lose to find the needle bearing holes
GOOD STUFF you guys... I came to help o1rk but it got done by lordherald...:D
Thanks! Bubbie I had that same problem first time i did that in class
CLASS,,,,, Lucky you, All I get Here is a Big Whipping from Glider when I'm wrong...
That is His class for me : He ties me up and uses the Leather..
He is a nice guy and seriously LOOK at all the things in Self Help,,,, NOW That's a CLASS in its self...:newsmile093: and FREE... Mostly Glider Built..:newsmile011:
