free website stats program No 6th Gear | Harley Davidson Forums
No 6th Gear
Turk55
So I installed a 30 tooth primary gear on my 09 SG and for some reason now I can't get into 6th gear, any ideas?:newsmile07:
Not doubting your abilities, but have you counted your shifts? I know that changing the Primary (compensator & clutch basket) gear ratios disables the 6th gear light. I assume, you changed your front drive belt pulley from 32 to 30 tooth? Maybe that disables the vss' ability to determine the gear, and the 6th gear light won't come on?
