The pipe plugs in front of the oil filter mount are for a oil cooler, right?
If so, do you have to do anything behind the oil filter? i.e. change or add a
directional fitting? If not, how does oil go through filter/cooler and back to engine?
I was looking at a Jag cooler. Good, bad?
Do you need Jags adaptor for cooler to work or will factory oil holes work?
Thanks In Advance!
wilks3
Thanks In Advance!
wilks3
