Posted by "Bud White"...
Well decided to install the oil cooler tonight maybe a hour to do if that...
First Remove the old Filter...
Then remove the oil filter adapter...
Metric 22mm Socket fits just fine...
Install the gasket on the adapter then install adapter onto engine...
You will need a 7/16 Allen wrench not a common one for the tool box I bought one when I ordered the kit and I'm a repair man not one I ever used.
Next remove Volt Regulator and reposition wires The instructions are really lame here...
Then assemble the Shield Bracket and oil cooler together...
Hang the oil cooler on the studs for regulator and then hang the regulator...
Make sure to space you hose clamps so you can re tighten later if need be...
install filter,fire it up check of leaks.
I know they say they have a 185 degree thermostat but it seemed to open a bit fast temp was only running about 115 on a thermal gun then dropping fast to re warm up .. i know there is a difference reading outside but that 70 degree difference
