how much will a hd premium oil cooler cool your oil down say on a day its 85 degrees out side 5 10 15 20 degrees or so with synthetic oil also
Yours showing to be a 2003. I'd say BUY a
side mounted 6 row JAG with the oil filter thermo like I have on my 09 King.
Mounting on the left down tube, easy and looks great. I bought the Premium JAGG cooler from M&M, and 6 row was enough.
Can't tell you actual degree numbers.
Using synthetic oil (I use 20/50 Redline) and having NO oil cooler for some time ...Then installiing one here in Az.,,,,,,, A BIG Difference.
in Az. it does get HOT..
So Far, I have not noticed the parade mode ON as often with the oil cooler installed.
Full Synthetic Oil and a Oil Cooler Make a Big Difference and it's well worth the investment.(JMHO)
Using a Dobeck Gen 4 also helps control the heat by allowing ME to adjust fuel (AFR) to any settiing I deem necessary...
low speeds in town I set Richer=cooler and speeds up at Cruise= leaner setting.
