Will adding an oil cooler have any affect on oil pressure? (raise it, lower it?). I know it would be safe to do, I'm just curious about the fluid mechanics.
This would be for a 2010 RKC with 96 ci Twin Cam (bone stock).
YES,
usually Coolers help keep the oil Pressure UP, Cooling the too hot oil otherwise tooo hot and dropping the Oil pressure......
I Remember the feeling of seeing LOW Idle oil pressure on my oil gauge before I installed the cooler.
All of the forums and all the knowledgeable people I've talked to say NO difference pushing the oil around NORMAL oil coolers like used on our HD's.
I agree with the MANY.
When you first open up oil to a cooler it may drop a little from making a New flow direction but that is just momentary. When it catches up or fills oil cooler being New,,, no difference seen on My oil cooler ever after that.
(jag 6 row w/auto thermostat).
That is how I see it... I run 20/50 Redline and out on the road(not city stop n go) I never see any drop from HOT oil... AZ. IS HOT.... My pressure stays at 40 to 45 lbs constant above idle (2200 RPM guess).
When I change oil filter, I always fill the new filter sitting up-right, to the threads with fresh oil... let sit for a few minutes (absorb) then Install it...
Less time to fill it as Oil pumps thru the oil filter THEN back into the motor..
So EXtra oil fill there, Helps build Early Pressure... (I am FUSSY)
(Hope this is understandable)
