Well...that's your choice, but then you'll need to learn to live with the fact of having oil drips/stains on your bike + leg.
HD motors are designed so the crankcase vents into the air cleaner. Air under the pistons on the downstroke of the crankshaft has to be vented & the normal way of doing this is to vent it into the A/C. This air has a mist of oil in it and is vented so MOST of it gets recirculated through the intake and out the exhaust, however, some of that oil mist collects on the air filter and, over time, drips. This is perfectly normal....exactly why regularly scheduled maintenace of the air filter is needed. My oil temp never runs over max spec - even during hot/muggy summer rides & I run level 1/2 qt low. Now if you want to start stuffing objects inside your intake - go ahead, but that sounds more damaging than a little less oil...imaging that cotton ball getting sucked inside your motor. >.<
