Ken,I have removed the outer on a lot of bikes in the last year to re-wire the passing lamps to work all the time and have found that quite a few no longer have the foam strip,these are the same guys that complained the radio was glitchy after they rode in the rain.We replaced any damaged or missing ones.When you replace it make sure you know what type of foam you are using.You have to use a closed cell foam.If you don't the open cell will absorb the water and act like a wick to the inner components.
Steve, since you have wired a lot of bikes for the passing lamps to stay on with high beams, have you seen any problems with too much current draw night driving??? That has always been one of my concerns doing it for a customer, since the factory see's fit not to do it.Ken,I have removed the outer on a lot of bikes in the last year to re-wire the passing lamps to work all the time and have found that quite a few no longer have the foam strip,these are the same guys that complained the radio was glitchy after they rode in the rain.We replaced any damaged or missing ones.When you replace it make sure you know what type of foam you are using.You have to use a closed cell foam.If you don't the open cell will absorb the water and act like a wick to the inner components.
I believe the factory does not wire it this way as I believe in most states it is illegal to have any other lites on when main lights are on high beam.Steve, since you have wired a lot of bikes for the passing lamps to stay on with high beams, have you seen any problems with too much current draw night driving??? That has always been one of my concerns doing it for a customer, since the factory see's fit not to do it.
Thanks classic, I never thought of that, but makes perfect sense.I believe the factory does not wire it this way as I believe in most states it is illegal to have any other lites on when main lights are on high beam.![]()
