Thanks Iceman but those are AMPS connectors. Usually those are for the sigs wires only. The main switch group runs from either Deutcsh or Molex.
I will go ahead with the molex first since I got a hunch those are what he is having trouble with. If they are Duetsch then he will not recognize the following.
Biffy if you are the one that pulled them apart, after you initially separated the two connector sections (male and female), then you would have had to grab the center hole in the recessed plastic plate and pull up (or out) on it about 3/16 of an inch travel. I use small needle nose pliers when I do mine. Some folks hook the hole with a curved pic tool.
After you get the wire pins back in you will need to press this plate back in before you assemble the two sections back together.
As far as the pins they will only go in one way properly. You will know something is wrong if they are not the right way. If I remember correctly you turn the crimp side toward the connector housing (instead of away from it). BTW it's the same scenario with the AMPs if you are having trouble with them also.
Once you start in with pin make sure it stays straight since the wire will sometimes try to twist the pin as you go in.
