free website stats program Piston compression psi help | Harley Davidson Forums
rush
Hey I need some help finding the correct PSI reading when doing a compression test on a 2012 wide glide with a stock unmodified 103 engine. Anybody know what it is? All the searching I've done here and other places has only given me PSI readings on modified engines. Not a stock 103.
Thanks in advance for any help
Your engine is 9.6-1 ratio doing the math it brings it out to 141 psi.
The math: 1-1 = 14.7 psi... now the magic 2-1 = 29.4 psi... that is 2*14.7 = 29.4 psi.
General rule of thumb 135 psi or better is good for gas engines.
Welcome to The Forum
With a good gauge no leak down and throttle full open you should see 180 lbs both cyls +or - 5 to 10 lbs If you have ACR be sure they are working properly before you do a test
Thanks for the reply's, and I do appreciate the help, but the first reply is 135 psi the other 180 psi. So I'm still stuck on what I should be seeing for a reading.
My Twin Cam service manual does not have compression values, but both my Evo and Shovelhead manuals say compression should be over 90 psi. @ operating temp., with less than 10% variance between front & rear.
The 180 psi Jack mentioned is what I normally think of as good. This is for stock or moderate cams. Cams with a lot of overlap, can significantly change the numbers.
Ok I last heard 125 psi from someone who said they had a service manual. But that sounds low for a 103 engine. The psi for a sportster I rode for a little while was 220 to 225.
Sportster, Fatboy, 1200 cc, or 400 cubic inch, pretty much the same. It's psi, not total pressure.
Stock 103" using the stock 30* intake cam and .045 head gasket...
.....static compression= 9.87:1
corrected compression= 9.43:1
Sea-level should Pump 196.7 PSI
125 would be the lowest reading before HD would be concerned with engine problems, the 96 motor calls out for 100 being the low number
