CR. Chancho
Good day folks, I'm new to the forum, I'm a retired Harley Tech Living in Costa Rica, I'm having an issue with my 2008 Softail Deluxe, I'm getting the PO262 code Front Injector High, I have checked resistance on both injectors and both are within range, I have checked the wiring for shorts and opens...all good, I have checked all ground points ...all good, I have checked resistance from ECM connector to the front injector...all good, I have checked voltage from pin 87 on the relay to the injector...all good, I have swapped the front injector with the rear and still get the PO 262 code on the front injector, also when it is cold it will start on both cylinders but after it warms up the front injector shuts down, my personal diagnosis is the ECM is faulty does anybody have any thoughts?
Unfortunately there is no dealership in Costa Rica to test the ECM
