bigdawg5000p
i had indie shop replace stator regulator and battery.. for a few months prior to this i had been hearing a popping out of where the points cover is. i figured cam pos sensor was going bad. when i picked up bike from shop for charging system replace it wouldnt run. it would idle but when i turn throttle it would die.. when i could get the rpms up it would run rough ,backfiring like crazy and very hard to start.rpms going up and down..i checked cam sensor and when i messed with the wires it started running a little better,, still runs bad but better.. so i replaced cam sensor and it fired up and ran fine for a minute then seems like when it warmed up.. same thing.. i need help i have set and re set timing ,changed plugs , check all connectors and battery ,, any ideas ??
1998 flhtcui 1340 engine stage 1 breather and pipes
