I noticed a rattle coming from my primary on my 2003 dwg. Pulled it down and noticed the alignment was off. After measuring as the service manual calls for, I noticed that the alignment is off the same as the alignment spacer. My questions are, can you go without the spacer to correct this problem? What would cause the alignment to be off that bad? The torques were correct, everything was in good order, correct placement of spacers. Is there a problem with my mainshaft endplay causing this? Im really stumped on this one.Thanks for any advice.
