free website stats program Primary Drain Plug | Harley Davidson Forums
Primary Drain Plug
r44s
As the stock drain plug is straight and if you're not careful it could be screwed into the primary, is there a replacement with a shoulder and O-ring as used in newer Softails? Thanks
If you have the NPT (tapered) plug in there now,you could retap the hole to take the newer plug with the "O" ring.
if your ride is a 2000
the prug is not straight and con not be scewed into the primary the plug you have now is a 1/8 pipe plug(tappered thread) just put allitle pipe dope on it before you re-install it you will be fine(unless you over tighten and crack your outer primary cover):D
