I have a nonProgressive stabilizer on my 05RG with V&H true duals. No fitment problems. Progressive is a great co. to work with and I'm sure someone here on the Forum will answer your question. Have you installed an aftermarket exhaust? With the new frame have you experienced any handling problems? If you search the forum there are several threads dealing with handling issues and installation of stabilizers, but the new frame is supposed to solve these issues. RedFish Joe found that the rear swingarm bolts were not torqued to specifications and once he took care of this problem his handling problems were solved.
