free website stats program Question about the 2006 Dyna | Harley Davidson Forums
Heck52
While I was freaking over the crank issue and looking around at different cranks, jugs and pistons I kept running into this line. Fits all but 2006 Dyna's. What happened in 2006 that makes the Dyna models so much different for a wide range of engine parts?
For once the dyna was used as the mule and got the 6 spd gearbox hence the differences
And the roller chain and hydraulic tensioners in the cam chest.
I thought they ALSO in the 06 DYNA tried out the NEW OILPUMP ?????
that would make sense with the new chain-hyd tensioners
correct if i'm wrong...
Also, I believe it was the first year (from late 2005 to early 2007) they tried the infamous UN-tried and UN-trued two-piece comp sprocket spring/rotor assy.
It seemed that when I was looking up parts like cams, alt rotor, or i think even cranks it said all TC except 2006. Anyway it must have been the great experiment year.
hello all
And yes i had all the moco problems of that year but all fixed now and 30k down. ESP is good for 1st year designed bikes
