P papasmurf42 New Member Oct 5, 2014 #1 has anyone installed reach handel bars on 2014 ultra if so do you need to replace clutch and brake lines
tourbox Senior Member Oct 6, 2014 #2 The dealer should be able to print out the instruction for them. Or read them to see if longer lines are needed. tourbox
J Jack Klarich Guest Oct 6, 2014 #3 View attachment -J04404 Handle bar install.pdf If this works, it will tell you how to install and what other parts you will need
