One For The Road
Hi,
I have a question concerning the rear drive belt on a 2005 Ultra Classic. I just changed the rear tire so I needed to set the belt tension. I don't have a Harley belt tension gauge so I used a fish scale to apply 10 pounds and measured the deflection with the rear wheel in the air. I set the deflection at just over 1/4 inch. I heard it was better to have it a bit on the loose side.
When I went for a ride I noticed a bit of whine coming from I think the rear of the bike. It only seems to occur when slowing down under 40 mph. I checked the tension when I got home. It was much less then when it was cold.. Is it normal for the belt to get considerably tighter when warm.
Thanks for you reply,
Steve
Steve
