TomnTerri
So I hit this really big pothole. Tweeked my rear wheel. 2003 FXDX.
I order a wheel from Bike bandit. Part number 40975-00.
Comes without bearings so I order bearings. I'm putting it together and I drop in the hub spacer from the old wheel and it is way loose. The old hub had a rim around it that supported the 1 in dia. spacer. The new one has no rim and the hole is more like 1.25 It seems to be the right wheel otherwise. It has HD stamped on it.
So my question is what happened? Did they send me the wrong wheel, or did HD change the spec on the wheel? Is there a different spacer that will fit?
Thomas
Thomas
