free website stats program Rear shocks adjusted to far out? | Harley Davidson Forums
rdoss
It seems that I may have adjusted my shocks to far out. They will not hold in place and don't appear to work at all. Any suggestions on where I should go from here? Besides to the nearest bar for a stiff drink...which is not sounding like a bad idea! Ugh!
Whet you say "too far out" what do you mean, or what did you do to make them function this way???
I think I spun the pre-load adjuster out to far. Adjuster plate popped out past the snap ring. What do I need to do to "reset" the shock to factory setting? Thanks for responding to my question...this is about to run me crazy!
Harley Davidson Community Start over again after reading here?
Be sure you have both adjusted to the same amount of preload or the handling will be a bit shakey, ie, same number of turns on adjuster plate or threads showing.
