CHAPPY46
I have a 2004 fxd that I installed the rear turn signal relocation kit because I was installing new saddlebags. I road the bike for a day and had no problems till I got home that night. The key symble on the speedo was on and I found out the rear right signal light was not working. I have the run-turn signal modual that allows the rear turn signals to be a run light as well. I checked the wires and found no sign of a break anywhere. I turned the ignition of then on again and the run light was not on. I checked the bulb by switching side and the bulb was fine. It worked with the 4 way flashers on and the the turn signal worked as well. but the run light on the right side would not. Rechecked all wiring and terminals and could not find anything. Can anybody HELP PLEASE!
