glimmerman
changed out the bad trans on the ultra. before i pulled the rear axle, i marked the location of the adjuster cams on each side. with the new trans in and starting a final button up, i noticed the right side cam is nowhere near the marks i put on there in relation to the nub. i'm about 1/4 inch less on the right than the left. do i need to drive the right side down to the marks to make it tighter or is this just where the cams lay? is there some way to insure the NEW tire is running straight with the bike? i'm not taking it off the lift until i'm sure its in the correct position. man i hate these cams. yes, i was stone sober when i took it apart!
