free website stats program Removal of Triple Clamp Shroud | Harley Davidson Forums
Good Evening Everyone,
Hello...I am looking to remove the triple clamp shroud on my '08 Heritage to get to my aux lamp switch to fix an electrical problem - help!
I removed the detachable windshield and one phillip screw thinking the left tin shroud cover would come off, but no luck.
I am unable to locate this in my service manual.
the 2 bolts on each side of the forks that clamp the light bar on need to be backed off, then undo the 1 button head on the left tin and the 2 on the right side. if you want to take the front tin off you have to remove the head lamp
You shouldn't have to take the winshield/running lights mounts completely off. Just loosen up enough to slid the rear tins out. They are slotted...
If its just a lamp out, I would pull the bulb first and make sure its good still. I thought the same thing with mine but it was bulb.
Mad Dog Jim,
Both of my lamps are out. I did notice that the wire connected to the toggle switch behind the tin shroud was loose/not securely connected.
Thanks for the reply.
