I'm hoping someone has some ideas on this. I have an 08 Electra Glide Standard. It has a Stage 1 and Vance and Hines FL Slash Cut slip-ons. Intermittently when I start it up, the right side handlebar will shake quite a bit more than the left one (which seems to shake as much I would would expect it to, not much at all). I don't have anything fancy bolted on to either side of the handlebars like cupholders, gps, etc. After riding for a while, when I stop at a light, it usually has stopped. If I start it up and see it shake, shut it off and then start it again, the shake will still be there. I spoke with the dealer about it but they advised it wouldn't be something that is covered by my extended warranty as it was considered to be a loose fastener and therefore not covered. I was quoted 2.5 hours to "fix" it s they said they would have to take the fairing apart to tighten whatever it is. I'm not overly handy other than oil changes :small3d029: so I don't really want to try it myself if I can help it. Is what the dealer saying seem reasonable? Is there another possible problem/fix it could be? Thanks.
