free website stats program Road/spot lights on a streetglide | Harley Davidson Forums
olrider
Bought the Harley spot light kit. These come without the lights. Thought I would run the 50 watt halogen bulbs so I bought a set. They came with the bulb and reflecter backing but no cover glass. I can't seam to fine the glass anywhere. If I can't find it I will have to go to seal beam. That is not my first choice. Any help on locating the glass lens?
Have you tried the Harley web page for the glass?
It would be nice if you would identify the lights you bought if you want any help with a part number.
The only compatible (PG13 base) 50 watt bulbs I could find had UN-shielded filaments. They were quite dazzling for drivers coming toward the lights. I also recently stumbled across 4 1/2 inch sealed beam bulbs with a high beam and low beam two filament set up. I have no problem running the passing lights on high beam and having a high and low beam passing light is an interesting idea. Haven't decided yet if I want to go to the work and expense to buy and wire up all of that. IIRC, they are in the latest J&P catalog and use a standard 3 wire auto plug from the pre composite headlight days and sell for around $15 each. (Bulbs only, not the mounting hardware)
