On my 09 street bob. I recently put on rush slip ons with 2.25 baffels k & n air filter with stock air cleaner box and a doebeck tfi. I have tried every adjustment possible on the tfi and even went back to stock air filter and still can not get the pop on decel to disappear. Does anyone have any Ideas?
Thanks
I don't Know all about the pipes,,,, Seems though, I have heard those pipes do have that characteristic of the POP on decl...
Your Harley should have the "gas shuts off on decl. feature" on this new of a bike..
I know my 09 FLHR throttle by wire does shut off the gas so it won't pop..
Harleys STOCK are sooooo lean to start with this Feature is Needed..
I doubt your problem is a lean condition caused by the TFI ,,,,, IF HOOKED UP correctly and working (set to the Suggested settings)... If set Close to their settings it should function great...
The only two Pots that Most will set a little differently are the First Pot #1 (green),,
that is Set at Fast idle(2000 rpm) after warmed... Close pot one and then Open it,,,, Turning Until TOO MUCH fuel is noted by the motor stumbling then turn back IN (down) until smooooooth and then Just a WEE bit more,,, (Wee= very Little)..
On the # 2 pot IF gas mileage is Bad, this pot can be turned in a 1/2 number or so from Suggested setting ....
Just more information please??
??? do you back-off at High RPM when pop occurs or is it at Normal Off speed decl. and Just How Big a pop and many is it...
IF it didn't do it Before the exhaust change, it is probably the exhaust muffler system.. Maybe some one out there with the Same mufflers will chime in here..
You are going to get "intake leak" and maybe other things to check from others but I doubt it to be the problem...... Exhaust Characteristic is my thinking.
On some muffler systems the pop is going to be there and It is hard to tune it out...
