Hi people, new on the block and in need of some help.. as the thread title suggests im fitting an SE compensator to my 06 Dyna, my question is do I need to change the stator out for a newer type?
I ask as there is a lot of difference in the internal dimension of the two rotors, ie the SE rotor that comes with the compensator is 10mm or so larger in diameter internaly than the stock one fitted to my bike, the instructions that come with the compensator do not mention a change in fact they indicate a direct replacement of the compensator only.
Thanks for any advice.
Hilly
Hilly
