free website stats program SE Ventilator a/c breather bolts? | Harley Davidson Forums
Xrider
The screamin' eagle ventilator kit for an 09 touring bike replaces the hollow bolts and breather tubes with sold breather bolts? The sold bolts are shown in the instructions, so they are the correct bolts. How does it now vent?
When I purchased the SE Air filter for my 09 SG the directions said to use the stock breather bolts.
I see. For the Ventilator is says the only thing to keep is the button head screw and discard everything else. There are new breather bolts that are seemingly solid but another forum mentioned that then are open in the back with a hole at 90 degrees half way through on the sides to breath...
There is an new oil leak under the engine since installing the new a/c...
I did the same thing and the bike ran terrible...You have to use the stock breather bolts with the Screaming Eagle kit.
