When I shift there are no grinding sounds at all just a slight jerk and thats all a rather smooth operation.
Thank you for your input I'll stay on the safe road and use the clutch. I don't need any avoidable problems. Thanks Speedyron
it is possible to shift gear on any automobile without using the clutch as long as the revs are correct and the gear box is in good operable order.
i do it when on the strip - im cheap and cant afford an air shifter, basically you rev the motor and apply pressure to the shifter as you slightly drop the revs the bike will shift up and you can bang the power on without loosing much.
i dont reccommend doing it all the time but it is possible
On my 06 Dyna I notice I can shift gears without engaging the clutch after shifting from first to second. How bad can one damage the trans by doing this and is this possible on other bikes or is it a flaw? I can up shift and down shift is that strange or what?
