About a year ago I had a short in my brake light wiring that I found to be in the handlebar switch. Rather than replace the switch or the affected wiring I just unplugged the switch wire from the harness inside the front outer fairing, thus eliminating the short and leaving me with brake lights activated by the rear brake pedal. Now the short has returned and I checked everything by unplugging the rear brake light switch, no help, and unplugging the harness under the seat that goes to the rear lights, no help, the short remains. All other lights and systems work normal. Any other ideas before I'm forced to use the dealer?
