need help wiring up my ignition. just replaced my evo with an ultima 100 ci it came with a single fire ignitiion so i have changed to a single fire coil. i know how to wire most of it but still have a few that i'm not sure of.
1st voes wire i do have a voes switch i know i have to hook up the violet wire to the voes and ground to vows. my current setup is 2 wires coming out of the voes and into a plug that has 2 wires coming out of it and into the frame. i am wondering do i take this plug completely out and wire the violet wire to one of the wires and ground the other to the frame or trace the wires from the plug back to battery area and cut the wires and wire the new one in.
2nd. wire from the coil to the battery + wire i know it needs to go through the switch should i trace the wires currently at the switch and wire it in this way or run a new wire straight to the switch
thanks for any help if there is some other way of doing this it would be appreciated
