william5763
Hello, I have a 2000 Electra glide. When I start it, I can feel a slight forward kick. Just wondering if its normal? Thanks!
When cold, or the first use of the clutch in the day, the clutch plates are stuck together, held by the cool oil. I call it "stickage." The plates need to be twisted apart. I never try to start the engine in gear for that reason. The same holds true for your first shift into gear for the day. That big "clunk" is due to "stickage." I always start in neutral, with the clutch pulled (likely redundant). Then, I pull the clutch for 20-30 secs and crack the throttle a few times, to try to get the clutch plates to come free, before dropping into first for the first time of the day. I rarely get the big "clunk" anymore.
Enjoy,
Rich P
