markfsanderson
Hello,
It took me a couple of weeks, off and on to go through my 1000 mile maintenance procedure on my 2011 Super Glide Custom. Busy at work, not ever enough time to be on or around the bike . . . I've learned a lot about the motorcycle and managed to save some dollars. Even when adding in the cost of tools, a new motor cycle jack from sears (The cheap red one, I just roll bike up on to some 2x8 pine boards and jack it up with those H-D bumpers installed) - I just about broke even. The next one @ 5K will be the real money saver! So here are a couple of questions that I'd love to get answers to:
Any help or advice would be much appreciated . . . . Thanks!
Mark:newsmile026:
- How do I tighten the rear brake pad pin? I can't event figure out what kind of socket to buy for this thing. Its not like any other fastener that I"ve seen on the bike.
- How do I tighten the rear brake master cylinder mount nut? It seems like a combination of the brake line going through the center of the unit and the way its mounted prevents a 'normal' approach to tightening it.
- What is GP40 Brake Grease? Can I use any moly brake grease? Should I put it on both the brake/clutch handle pins and the rear pins on both front and back brakes?
- Where can I purchase a spoke wrench/torque wrench from? It appears that H-D doesn't sell the one mentioned in the manual. Also, I have a couple of spokes on both front and rear wheels and their 'partners' 180 degrees across that don't sing 'ting' or 'tong' when struck, but aren't dead or loose either. They seem to have a much lower frequency ring to them - but aren't dead. Show I pay attention to these? If so, how?
- The recommended minimum torque for both front and rear brake master cylinder cover is 6 inch/pounds. My smaller torque wrench bottoms out at around 16 or so. I've seen gunsmith torque wrenches that start around 10 inch/pounds but nothing smaller. I just snugged the screws and checked for leaks . . . I don't have much of a 'feel' for mechanics, and I'd like to have a torque wrench for all of my fasteners if possible. Any ideas on this one?
- I put in synthetics in all 3 holes, mobile one for the engine, spectrum chaincase, redline transmission and a K&N oil filter. . . everything seems to be working very well. However, while riding at between 20 and 30 MPH w/the engine at idle and the clutch pulled in I hear a noise that I never heard before. Its a soft, low frequence hum that I cannot change by applying either brakes or clutch. If open the throttle I can't hear it any more. My extremely wild guess is that its the tires (they are properly inflated) and that I never heard it before because my bike is quieter since the synthetics. Does this sound plausable?
Mark:newsmile026:
