markfsanderson
I've some questions that are kind of all over the place . . . any help or advice would be greatly appreciated:
1) On my rear fender, I've noticed some very light scratch marks . . .just barely visible but still enought to annoy me. Is there some way to rub or buff these out? Rouge/buffing compound? Is the H-D paint job thick enough or of the right type that I can do this w/out damaging the finish?
2) Dang Clutch adjustments . . . so when I started my 1000 mile service interval I replaced the chaincase fluid and the clutch felt good to me and it seemed to be in spec as well. So now, about 400 miles after I did this, I'm now not so satisifed with the clutch feel and seems like its just a bit loose. Must I replace the access cover seal each time I open it? I'd like to adjust the clutch - 'tighten' it up a bit . . . must I replace the clutch access seal? The motorcycle has about 1400 miles on hit . . .
3) Oil cooler install . . . I'm thinking of getting a 10 row oil cooler - its pretty darn hot here in the Texas Hill Country lately . . . Is it required that I drain my oil to install this device? If I did, can I just pour the oil back in after draining it? I did an oil change about 400 miles (mobile 1 synth) and am not in a hurry to buy new oil (Kind of spendy!).
Thanks for any help offered!
Mark - Thanks!:newsmile026:
