Stick with the stock HD plugs. All the fancy ones do it empty your wallet faster, they don't run any better.
IF you must....
Being the owner of a shop and being a wrench for the last 42+ years, I tell all my customers to run the plug that the factory put in there. There are a few exception in the case of heavily modified engines but as a rule, run what the factory put in there in the first place, and they're a lot cheaper than the aftermarket stuff.
I agree there Jack. Unless you raise the compression ratio of the engine or run a cam with a lot of overlap, there's really no benefit to the fancy plugs.
