WideGlideWilly
My 07 Wide-Glide experienced some craziness last week. Speedo went nutz, turn signals wouldn't cancel and the bike wanted to cut out when decelerating. After troubleshooting w/ a multi meter and some online guidance, it became obvious that the Vehicle Speed Sensor is bad. So I called my favorite parts guy at the dealership and he had two sensors in stock however, he also said that HD is coming out with a revision to this part so I asked if this was a high failure sensor. He said NO. HHHMMM! So why the revision? Wouldn't you think they should recall this part? I have recently talked to several guys that had a VSS failure or have replaced more than one. I haven't seen any bulletins on this. I don't want to fork out $60.00 every 10K miles for a new speed sensor. Poor engineering or manufacturing, I could care less. But I don't think it should be at the owners expense. Your thoughts? ~ Willy
