My knowledge this way is geared to small block chevys where if you find no intake leak I would look towards the timing chain stretching as the syptom is the same In the case of an Hd cam chain or nylon tensioners wearing would be my guess.
HEY OUT THERE IN HARLEY LAND,MY 96 FXDWG HAS BEGUN TO "SPIT" BACK,ITS ONLY OCCASIONAL,LIKE WHEN I GIVE IT A LITTLE TWIST BETWEEN GEARS ON THE CHANGE DOW.Is this a mixture problem,or the beginnings of a trip to the mechanic??
Only it' a 1996 EVO motor that has a gear driven cam.:s
