J jddd95 New Member Oct 27, 2011 #1 My Road King won't turn over. It started this morning after 3 tries. All it does is click, any ideas?
fin_676 Experienced Member Staff member Moderator Contributor Oct 27, 2011 #2 Battery charge low, loose cables at the battery or starter or main earth point from the battery Brian
G glider Veteran Member Oct 27, 2011 #3 Brian has you covered, it could be a bad connection on the battery or starter, possibly a bad battery. Load test the battery after charging it.
Fritz Member Oct 27, 2011 #4 If you never changed the battery from stock and you got 6+ years out it, you got good & lucky. My guess is get a new battery
J Jack Klarich Guest Oct 27, 2011 #5 Check the connection at the solenoid also, the one under the rubber boot, Clean and tight here also:s
J jddd95 New Member Oct 28, 2011 #6 I checked the wires and clean the connection. Didn't work, I jumped it and let it run for about 10 minutes and watched the head light go dim and cut off. Any ideas?
SledDog Senior Member Staff member Moderator Oct 28, 2011 #7 Just about dead battery. No output from the charging system. Could be your voltage regulator or the stator. From our self help area How to check a battery Starting system checks Charging System Checks Last edited: Oct 28, 2011
