free website stats program Starts but runs irregulary or misses | Harley Davidson Forums
rjsogard
Hi all rich with a 06 WG problem.
Well this morning i went to start my bike and let it warm up it started but has a low idle then it stalled so i started it again after a min it stalled again. after i started again i revved the engine at a constant speed it seem to be fine so i rode it around the block I felt a misse fire but NO back fire threw exhaust. my engine ck light came on and the batt light came on.
so i limp it to my house and had no time this morning to work on it untill this after noon any ideas.
I did fill it up with shell 91 octane 4 gals 20 miles ago
stock battery
also how do i test the reg and alt and stator with multi meter thanks rich.
you said it's the stock battery on an 06. I don't know where you live but around here the temps are dropping and chances are your battery may not be up to par especially if you don't use a battery tender.
Good luck, hopefully its just the battery:s
hello all well i just ck my batt it good just low at 12.35 but when i start it up at idle it drops at 12.11. so its not charging the batt i guess its the alt /reg /stator be the problem. any other choices? before i send it to the stealer its under warrenty ESP.
thanks glider will ESP COVER THIS? ALT AND STATOR REPLACEMENT and other damage ie clutch componets thanks again YOU ARE THE MAN!!!!:cheers
No reason why they shouldn't cover the stator replacement unless it is specifically mentioned that they don't cover it.
Read your warranty papers it should be covered I had a 92 and a 97 Bagger repaired with the same problems extended warranty covered all but 50 deductable good luck
thanks everyone i just got a call from the dealer they said the bolts backed off the rotor and destroyed the alt stator then fried the reg. the service rep told me i can take pics to show all. I am sooo glad i paid extra for the ESP!!!!! or it would be $850 THE moco should really look in to this problem its very common as i read and again thanks GLIDER!!!!
