I have a 2004 Road King and have recently noticed the stator plug is leaking a little primary fluid-just a drop or 2 on the ground after a short ride.I put new crank seal in and replaced the stator maybe 4 or 5 months ago.The oil from the engine isn't overfilling the primary.Is there a way to fix this problem without replacing the stator I just put in? Thanks,Ben Medley
2004 FLHR
S&S 510 gear drive cams
Mikuni HSR 42
Thunderheader
Twin Tec Ignition
S&S single bore dual runner AC
Screamin Eagle Hybrid Billet Cam support plate and oil pump
2004 FLHR
Mikuni HSR 42
Thunderheader
Twin Tec Ignition
