StGlide1958
The tip light (led board) went dim on me. I have a fix you all might like. Rather than buying a replacement assembly, remove the assembly from the lower portion of the fender. The LED board inside is easily accessible by carefully separating the outer portion from the assembly. Two wires are soldered to the board (black and a black with white tracer). Replace the board with a LED strip like Stingerz or the ones you can get at Harbor Freight (10 bucks). Solder the Black with white tracer to positive, plain black to negative. 3M adhesive tape is used to place the replacement LED.
You now have a brighter tip light and a fraction of the price.
