tkmorris269
Here's my situation friends. I have a 2005 Road King EFI. I had installed Vance & Hines V02 intake, Vance & Hines Dresser true duals and Vance & Hines Fuelpak. Programmed Fuelpak with MAP from V&H and bike ran fantastic for about 3 months. Took a 1000 mile trip after all this installed and no issues. Even got about 45MPG. I then decided to change handle bars. Went with 13 inch apes and Magnum Chromite extension kit. After installing the handlebars, I started having a problem with bike wanting to stutter when accelerating. If I let out of throttle it sometimes dies. Strong smell of fuel. Engine light will come on but then go out. DTC codes are P0261 and P0263 and then PN 32915-05. I tried disconnecting the Fuelpak and going straight back to the ECM with no change (thinking maybe there was a problem with the Fuelpak). Really not sure where to start with this problem. I've read some older stuff on this forum with similar issues and some members suggesting maybe a System Relay or bad connection at the injector but they also asked about whether the member having the problem had a fuel management system so I wasn't sure if you guys think that changes the diagnostic or not. Thanks in advance for your help. These forums are invaluable for these types of issues.
