free website stats program TFI Question | Harley Davidson Forums
TFI Question
bobbeidel
Will a TFI be of any benefit if I have a stock air filter and Rinehart pipes? No other modifications. 2009 Road Glide !!
Yes. You can eliminate the EPA-required lean condition, increase pep, and cool the engine significantly, with a better AFR.
Enjoy,
Rich P
Screaming Eagle mufflers, stage 1 air filter. I was getting a lot of decel popping before the Dobeck. It completely stopped that and also seems to be running a bit cooler.
Rinehart pipes and K&N filter. Filter is PN HD-1508 and is not a high performance filter but simply and upgrade from the stock filter in that is it can be cleaned.
