hello all,
I have a crazy transmission leak, let me explain.
I have a 2006 street glide with a new 5 speed harley trans.
I installed a wide swing arm for a 200 tire.
So i put in a longer output shaft from baker.
I have a king kong clutch.
I have 126 s&s motor.
I have a leak that is crazy, It almost emptys the transmission of oil.
I have taken the primary off 3 times and cant find anything wrong.
It seems to be coming out of the out put seal of the trans,
The quad seal is mint and shaft seal mint.
I understand that harley vents its trans threw the output shaft of the trans.
my vent tube is fine,J rubber hose is clear.
The baker cluch adjustment bolt is completely round, instead of the flat side found on the harley adjuster bolt.
after a short ride and i let it sit,, it almost emptys the tranny of oil from the trans rear shaft seal.
any ideas?
thank you for your thoughts.
any ideas?
