free website stats program Throttle cables | Harley Davidson Forums
Throttle cables
karthy
I'm just slow but how do you install the cables into the grip. I bought a project bike with no cables. How does the idle and throttle go in and wrap around?
Karthy
The controls are 96 up and snap in. The cables that snap in are for cv carbs which use longer inner cables. The carb I have is a butterfly type which use the shorter inner cable. Cut the inner cable ends and removed from housings. Cut the housings to the lenght I needed. Put inner cables back into housings. Made two barrel cable clamps 1/4 inch to fit carb. linkage. Installed cables into clamps and cut to fit. Works great and is alot cheaper than buying new controls or carb.
Johalber
