RSQCAL
I've got a '96 dyna convertable that started early in the riding season with a slight ticking sound that seemed to come from the lower front of the primary. I've checked the compensator nut and retightened to specs and readjusted the chain tensioner aswell as check the exhaust manifold bolts with no luck. The tick almost seems to turn into a rattle under power and is definitly influanced by rpm's and load. In the garage idling it almost seems as the tick may be coming from the cam area. I am also getting some oil spray along the right side of the engine now after decent ride. I've read on the forum that a bad breather kit under the rocker cover may cause the oil problem. Could this also be the cause of the other symptoms. If not any other suggestions? I'm starting to get frustrated. Oil levels are good and I'm using Amzoil which was changed this spring about 1000 miles ago.
