hotrodjohn
I was tired of always having a mess when I changed the oil/trans/primary oils. I use a jack to lift the bike but I could not find an oil tray that fit under the jack. I made my own out of diamond plate that I had laying around. I just welded up a tray and made some cuts in it for hand access to the drain plugs and also bent up a splash shield that hooks around the jack and also clips into the tray. Drilled a hole in the bottom where it can drain into a collection tray.
I also found a PVC 1" threaded nipple that makes a nice funnel extension for the oil fill
Now if it would get warmer than 33 degrees I could try out all of these new ideas
