Guys I have a question on this subject. When it comes time for this sort of thing, is it safe to only rebuild the top end with a 'repair bore' size or can you safely install one of these big bore kits on top of a low end that has a lot of miles on it ?
I have seen Many go big bore(that is the 95" here) done after many miles.. Safe is a word that has to fit Each individual build and Motor....
Are the crank and rods in good shape? along with the bearings.? If not it will show up early on with the problems, Like You are thinking about..
I have done several builds with HD's with low to high miles on them...
I did have a problem with one build at 40,000 miles and that was because of the front rod bearing ticking AFTER i went From a 10.5/1 ratio to a lesser 9.25 compression change,,, Loosing the whole motor for a complete rebuild with ALL new parts, from bottom up.... SO that told me it would of happened in the first place with the Bigger build in time...
IF you want to feel safe, a New crank and rod assembly with new bearings will put your mind to ease SO be IT..
BUT to pull the engine down (out) to get to all the EXTRA build is BIG..... The top end Is easily done in the bike so I'd take My chances...
I'll do a 103" and Not touch the crank thingE and live with it that way... My run out on the TC96" is .0015 and that is Unheard of in this motor....
But for now, I'm really Impressed with the New Found Power of the 96" stage one,,, TFI and Now using the SE 255 cams. CCP = 210 lbs in both cylds.(checked accurately with two different gauges)
I will install a New Gen3 into this bike Before going 103 and report on that... and also the Gen4 When I Get one..... Hint hint...Dallas/Mark
The oil I use is a factor for "piece of mind" as I'm Not wearing out my motor as quickly as with Lesser Quality oils..IMHO
Now some builders are always changing out their motors for this cam or that and I doubt they do any BIG changes on OLD 80/100 mile motors, without checking the Condition of the crank/rod assembly..
Lot of wasted dollars to do it wrong:53:
