Brother, you're opening a can of worms here.
This has been a hot topic here for years since the 6 speed. Noticed my '08 SG main shaft bearing start to go around 26,000 and finally got if replaced under warranty at 31,000 and than started to go again at 43,000 and had replaced with a Baker DD7 and run Spectro Platinum now. 52,000+ miles and diggin' it.:s The best to you with your situation bro.
Didn't notice the other person was NEW...
Welcome and Please;
Look and find in the search area (right top of page) of this forum and Read.... Lots of answers and Problems Like stated above by craig Lee...
I still would like to know about the Lube/oil/?
I have heard Horror stories and some Good stories.. I don't think it to be ONLY a lube issue..
On Craigs problem, I always thought it to be a Bad Tyranny case to start with... IF it is the ones that were Improperly Lin-bored ???
the bearings would go out regardless of Lube..
Don't know the answer here..
I Have NOT heard of a LOT of problems but When It Happens to You....
I've been Lucky on getting a good quality built bike OF the Many I have bought New...
The 2000 FXDS was one that came with the BAD Cam Drive Ball Bearing and I never waited for it to Blow so HD would fix THEIR PROBLEM they Made MINE.... So I lost Faith on the HD Representation but Not the HD bikes...
There are probably FEW that have the Major tyranny problem and LUCKY for you it showed up Under Warranty...
My warranty is up in August of this year on my 09 FLHR... I have 20,000 miles on it now, (bought late when 2010's came out in Aug of 09)..
Problems on mine?
Maybe front brake rotors?? Will check when up on my jack lift.
One piece of Chrome Trim on front fender got Wrinkled... Over heated bulb ???
I replaced the front amber light cover on my own. I'll do the warranty thing on the chrome tip,,, IF they will replace..?
Using Redline Shockproof Heavy in the tyranny(many bikes) since New and The dealer out of state where I bought the bike SAID after asking him what lube He personally used.... He pointed to a full shelf next to his display of HD oils. His Full complement of Redline Products. He was Only TOO Happy to recommend them to HIS buyers of their New bikes.
This Dealer, KNOWING that new 6 spd. Tyranny had a Noise Problem he Suggested to use Shockproof in them..... Racing Motorcycles for years,, only wanted the Best to be OFFERED to his customers ALSO,,, it is what He Used.. Redline right next to the HD lubes....
NO Push Just CHOICE..
Cascade Harley Of Bend Oregon... Nice Dealer
