The reason I checked it was when it is in neutral it clunks a little bit, but if you pull the clutch in with it in neutral the clunk stops.
Doe's any one know what kind of fluid comes in the tranny from the factory. I just checked mine ( I have had my bike for 4 days ) and it was so clear I could not hardly see it on the dip stick, I had to check it 3 times to make sure it was there.
Chuck, Bubbie has given u good advice here, Maybe want to change the fluid yourself @ 1000 miles, you can use the self help section for details, The Formula + is probably in the tranny now, seems the MOCO decided a while back the Syn 3 not such a good choice:schuck60,
Would you describe the problem you are having a little better and we will help out with an answer..
agree with formal+ and NOT sin3:newsmile055:in the tranny
I use Redline Shockproof Heavy, it is Pink so it is seen easily and gives the best protection IMHO.
If the correct amount of Tranny Gear Oil is used in the bike (32 oz.) and no Leaks, I never check mine as it is always full
Unfortunately there are some dealers still using the Syn 3 in the transmissions.
